Feb 11, 2025 12:39 PM UTC
SPC58EC-DISP not recognized by device manager
Hi. I have a problem when trying to establish a serial communication from SPC58 to my PC. My device manager only shows SPC58EC-DISP in the "other devices" section.
1.  SPC58EC-DISP is connected with USB cable to my PC.
2. I have installed the drivers from the link that was provided in the DKReferenceCode: CP210x USB to UART Bridge VCP Drivers - Silicon Labs.
3. Installed "CP210x Windows Drivers"  and "CP210x VPC Windows" and "CP210x Universal Windows Driver"
4. I run the installer, example "CP210xVCPInstaller_x64".
5. When i try to update the drivers to the SPC58EC-DISP in the device manager, windows doesn´t find the drivers.
Kind Regards,
Joona.
Erwan YVIN
Erwan YVINBest answer
Feb 27, 2025 4:02 PM UTC
Hello Joona ,
SPC58EC-DISP has its own PLS FTDI chipset to debug
The driver in in the starter kit
Download SPC5-UDESTK
After you can debug and flash, you should have PLS FTDI in your device manager
To enable the Com Port , you should enable the VCP
            Best regards
                            Erwan
Erwan YVIN
Hello Joona ,
            Best regards
                            Erwan
