DS Kim.39
Mar 16, 2023 5:04 AM UTC
SPC584Bx chip. Some error occurred while downloading to the UDE SDK tool. How to clean or erase all in the flash for initilize?
We are developing products with SPC584Bx chip. The following error occurred while downloading to the UDE SDK tool:
Tu 14.03.2023 17:51:12.822, Success, Core2, UDEDebugServer, Connection to SPC584B70 target established: PowerPC Target, JTAG-ID: 0x20144041
Tu 14.03.2023 17:51:20.174, Warning, Core2, PpcJtagTargIntf, Write access to memory range 0x00FC0000-0x011BFFFF refused !
Tu 14.03.2023 17:51:21.667, Warning, Core2, UDEDebugServer, CRC check after download failed in memory range from 1000000H to 103D83BH!
Tu 14.03.2023 17:51:21.667, Warning, Core2, PpcJtagTargIntf, Write access to memory range 0x00FC0000-0x011BFFFF refused !
Tu 14.03.2023 17:51:21.693, Warning, Core2, UDEDebugServer, CRC check after download failed in memory range from 103D840H to 103E6E7H!
Tu 14.03.2023 17:51:21.745, Success, Core2, UDEDebugServer, Program with ID 0x1 - code size
255716 bytes - was loaded!
In the event of this error, I would like to clean or erase all in the flash.
Are there any solution?
Additional information as below:
0693W00000aJ5HJQA0.pngWe cannot start application and erase flash.
Is Flash dead or broken in the SPC584B.
