SKara.7
Jan 19, 2022 3:03 PM UTC
SPC584B - Issues with CAN RX
When I use the low level drivers that comes with SPC5 Studio, I am facing issues with CAN reception.
The Rx buffer only updates with the highest priority message. All the messages below that are ignored.
I tried with FIFO and Dedicated Buffer settings, but both have the same problem.
Please can you advise on how to fix it?
Best regards,
Sreejith
    Erwan YVIN
    Jan 20, 2022 9:12 AM UTC
    Hello ,
    could you send us your configuration.xml and your pin settings ?
    I recommend to check the status of your register with your debugger.
    (Chap 46 : CAN Subsystem of your RM)
    Best Regards
    Erwan
    SKara.7
    SKara.7Author
    Jan 20, 2022 9:25 AM UTC
    Hi Erwan,
    Please find attached the configuration.xml file.
    I hope you will be able to see the pin settings as well from configuration.xml
    What I see is, the other Rx messages are in 'wait' state. Rx buffer always captures only the highest priority message. The rest of the messages are in 'wait' state when I debug the return value of can_lld_receive() function.
    Best regards,
    Sreejith
    SKara.7
    SKara.7Author
    Jan 24, 2022 12:43 PM UTC
    Hi Erwan,
    May I know if you found any issues with my config?
    Kindly let me know if there is a solution to my problem.
    Regards,
    Sreejith
