Explorer
Sep 17, 2026 8:30 AM UTC
SPC584B-DISP Standard Pinout
Hi All,
Where can I find the pin map xml file for the SPC584B-DISP demo board ?
Erwan YVIN
Erwan YVINBest answer
Sep 23, 2026 3:34 PM UTC
Hello ,
 you can use SPC5-STUDIO to select the SPC584B target and configure the MCU’s pin resources through its graphical configuration environment.
However, SPC5-STUDIO does not replace the SPC584B-DISP board documentation : the tool configures the MCU pin multiplexing and generates project configuration code.
For the board wiring and connector mapping, use the SPC584B-DIS Discovery Board User Manual, UM2462, available from the SPC584B-DIS product page.
  1. Download and install SPC5-STUDIO from the official ST page above.
  2. Create/select a project for the exact SPC584B derivative.
  3. Open the pin/resource configuration, assign the required alternate functions, and run the tool’s validation/code-generation step.
  4. Cross-check each selected MCU signal against UM2462 and the schematic before connecting it to the board headers.
                         Best regards
                                        Erwan
Erwan YVIN
Hello ,
                         Best regards
                                        Erwan
