LBona.2
Apr 18, 2020 12:24 PM UTC
SPC584B-DIS GPIO configuration and usage
Hi I'm a student, I'm trying to program for the first time a SPC584B-DIS developer board. I'm trying to set 6 pin as GPIO because I want to control 6 switches by setting the voltage to 0V for close and to 5V for open but I can't figure out how to do it.
    Erwan YVIN
    Erwan YVINBest answer
    May 5, 2020 1:25 PM UTC
    hello ,
    You can configure the pin like GPIO
    and use the code as below
     pal_lld_togglepad(PORT_E, LED_4);
     osalThreadDelayMilliseconds(300);
     pal_lld_togglepad(PORT_A, LED_3);
     pal_lld_togglepad(PORT_D, LED_5);
    Best Regards
    Erwan
    Erwan YVIN
    hello ,
    Best Regards
    Erwan
    LBona.2
    LBona.2Author
    May 6, 2020 1:18 PM UTC
    Thank you very much for the help
    Ludovico
