Veniamin BELYAEV
Jun 25, 2020 1:41 PM UTC
SPC58 FLASH Memory state at delivery and primary programming
In order to reduce the programming tima at the production line for our SPC58 could you please help with the following points?
  1. What is the FLASH memory state at the MCU delivery?
  2. What are the recoomendations to reduce the primary programming during production?
  3. Can BAF be used for this? Is there any SW for using BAF for primary programming?
  4. How can the figures mentioned in DocID029264 Rev 2, June 2016 for FLASH programming time be reached? - see an image below:
0693W000001rUziQAE.pngThank you in advance,
Veniamin
    Erwan YVIN
    Erwan YVINBest answer
    May 25, 2022 2:08 PM UTC
    cf RM
    Erwan YVIN
    cf RM
