NBula.1
Sep 13, 2021 6:34 PM UTC
SPC570S MCU running FreeRTOS freeze upon receiving CAN messages
I have a SPC570S MCU running FreeRTOS and is connected to a CAN bus. I came across an issue where the MCU freezes randomly, when there traffic in the CAN bus before is it switched on. Could someone help me in this matter. This happens randomly, and I have isolated the problem by uploading two code stacks, one with CAN and one without.
Nisal
    Erwan YVIN
    Erwan YVINBest answer
    Sep 14, 2021 9:27 AM UTC
    Hello ,
    you should check the state of your stack.
    Could you increase the stack size of your application ?
    check the registers before your crash R13,R14,PC with the debugger
    Best Regards
    Erwan
    PChia.2237
    Senior
    Sep 14, 2021 6:09 AM UTC
    Have you try disable preempition?
    Erwan YVIN
    Hello ,
    Best Regards
    Erwan
    NBula.1
    NBula.1Author
    Sep 14, 2021 12:19 PM UTC
    Hi Erwan,
    I will try this. Is it okay to use the FreeRTOS function uxTaskGetStackHighWaterMark() to check the size.
    I have 4 tasks running.
    Nisal
