Patriks
Senior
Jun 17, 2015 5:45 AM UTC
SPC56EL54L3 not implemented in ''Platform Settings''
Posted on June 17, 2015 at 07:45
For an upcoming project, I would like to use the SPC56EL54L3 controller. But when I was setting up a SPC5 Studio project, I can´t choose this controller in the platform settings because it is not listed.
Is there a reason why this controller isn´t implemented in the ''Specific Model'' in platform component configuration?
Best regards,
Patrik
    Erwan YVIN
    Erwan YVINBest answer
    Jun 18, 2015 9:05 AM UTC
    Posted on June 18, 2015 at 11:05
    Hello Patrik ,
    for your information , the file is present on sourceforge too (SPC5-HAL Project)
    http://sourceforge.net/p/spc5-hal/code/HEAD/tree/trunk/SPC56ELxx/SPC56ELxx_Platform_Component/plugin.xml
    it should be present in the next delivery
    Best regards
                          Erwan
    Erwan YVIN
    Jun 17, 2015 9:36 AM UTC
    Posted on June 17, 2015 at 11:36
    Hello Patrik ,
    Yes , we have forgotten the enum device for SPC56EL54L3 in the platform settings.
    we will integrate it in the next release of SPC5Studio.
    in the attachment , you can put the file plugin.xml ''patched' in this following directory
    it works on SPC5Studio 3.5.
    c:\SPC5Studio\eclipse\plugins\com.st.tools.spc5.components.platform.spc56elxx_XXXXXXXXXXX\
    XXXXXXXXX is the last qualifier date.
           Best regards
                      Erwan
    Patriks
    PatriksAuthor
    Senior
    Jun 18, 2015 8:52 AM UTC
    Posted on June 18, 2015 at 10:52
    Hello Erwan,
    Thanks for the quick response. In your post, you write about the patched plugin.xml file. I think you forgot to attach the file to your post. Please can you post this file?
    Best regards,
    Patrik
    Erwan YVIN
    Jun 18, 2015 8:59 AM UTC
    Posted on June 18, 2015 at 10:59
    Oups ,
    file in attachment
    Best regards
    Erwan YVIN
    ________________
    Attachments :
    plugin.xml : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0TA&d=%2Fa%2F0X0000000bZF%2FgzsEwkrSyPBxcpe7egJv52XXSRq2jiRN9wyQiTBrFXw&asPdf=false
    Erwan YVIN
    Hello Patrik ,
    Best regards
                          Erwan
    Patriks
    PatriksAuthor
    Senior
    Jun 18, 2015 1:14 PM UTC
    Posted on June 18, 2015 at 15:14
    Hello Erwan,
    Thanks, that solved my issue!
    Best regards,
    Patrik
