orhanyilmaz
Feb 1, 2016 1:14 PM UTC
SPC564B70L7 LV Voltage Regulator Problem
Posted on February 01, 2016 at 14:14
How is voltage regulator requirements for SPC564B70L7?(or regulator circuit) I'm trying but not generated 1.2V core voltage.
Thanks.
    Erwan YVIN
    Feb 2, 2016 4:02 PM UTC
    Posted on February 02, 2016 at 17:02
    Hello orhan ,
    Maybe you can find the information in the Datasheet
    http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00272932.pdf
    Chapter 3.8.2
           Best Regards
                  Erwan
