Dariush.Tsh
Dec 6, 2021 6:20 AM UTC
SPC563M64L5 and SPC560P50L5 microcontrollers pin compatible
Are the SPC563M64L5 and SPC560P50L5 microcontrollers pin compatible?
I mean, can two microcontrollers be assembled instead of each other?
    Peter BENSCH
    Peter BENSCHBest answer
    Dec 6, 2021 7:56 AM UTC
    There is only one common housing variant for both SPC: the LQFP144. If you look at both datasheets, you can immediately see that the SPC560P50L5 and SPC563M64L5 do not have any pin match, so they are definitely not pin-compatible.
    /Peter
    Peter BENSCH
    /Peter
    Dariush.Tsh
    Dec 6, 2021 8:00 AM UTC
    OK, Tkanks...
