harsh2
May 23, 2016 9:17 AM UTC
SPC560D40L1: To drive a 26-Pin 7-segment display LCD from SPC56D-Discovery .
Posted on May 23, 2016 at 11:17
Hi All
i am driving a 26-Pin(4 COM+22 Segment) LCD display through
SPC56D-Discovery BOARD Using GPIOs & want to run a counter from 1 to 100 on LCD display.
please advise how it will be possible.
attaching datasheet of LCD.
    harsh2
    harsh2Author
    May 23, 2016 12:00 PM UTC
    Posted on May 23, 2016 at 14:00
    i have displayed the all segments with the help of delay logic & running the lcd at 50hz.
    Pls advise if any in-built lcd driver is there in SPC560D40L1 mcu, as i am unable to see in its datasheet.
    Harsh
    Erwan YVIN
    May 25, 2016 8:27 AM UTC
    Posted on May 25, 2016 at 10:27
    Hello Harsh ,
    There is no built-in driver
    Yes , it is possible.
    Could you give me your LCD Reference ?
    This LCD is supporting I2C ?
    We have already implemented some LCD drivers with I2C (sw emulated) to reduce the number of wires
               Best regards
                            Erwan
    harsh2
    harsh2Author
    May 30, 2016 7:47 AM UTC
    Posted on May 30, 2016 at 09:47
    Hi Erwan
    below is the specs of my LCD:
    Specifications:
    1. Operating Temperature: -30 to +85 deg C.
    2.Storage temperature: -40 to 95 deg C
    3.Operating Voltage: 5V
    4. LCD Type: TN Positive
    5.Connection type: Pin type
    6.Clock viewing: 6'o clock
    7. Drive condition: 1/4 DUTY, 1/3 BIAS
    8.Display type: Trasflective
    9.Polarizer colour: Grey
    Polarizer: High quality anticlar.
    Vibration On cluster: freq: 30-500Hz.
    I am attaching its datasheet also.
    No, it doesn't support I2C.
    Please advise, if i can drive it's display using GPIOs or any other best method.
    Awaiting for your kind reply.
    Harsh
    ________________
    Attachments :
    LCD_display_-_Electronics.jpg : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtbE&d=%2Fa%2F0X0000000aS5%2FX6xBk2_lW04eDgFMta0l76s6S8_jzLTm9EVQUAeHrac&asPdf=false
    Erwan YVIN
    May 31, 2016 7:37 AM UTC
    Posted on May 31, 2016 at 09:37
    Hello Harsh ,
    There is enough GPIOs to handle a TN Positive LCD. (cf screenshot)
    you should create your own driver by creating a new component or new drivers in SPC5Studio.
    I am checking in application team if some examples are existing.
    Best Regards
    Erwan
    ________________
    Attachments :
    2016-05-31_093435.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtfG&d=%2Fa%2F0X0000000aVX%2Fkgb80xikGIG84QMQA.8wm6ZtIV0aW28RhppRYYKMFTM&asPdf=false
    harsh2
    harsh2Author
    Jun 13, 2016 11:40 AM UTC
    Posted on June 13, 2016 at 13:40
    Hi Erwan
    Please let me know if there are any example codes available for this.
    Harsh
