ssk
Mar 18, 2015 2:55 PM UTC
SPC560D30L3 - ADC states
Posted on March 18, 2015 at 15:55
I am trying to use the ADC driver (ADCD2) for SPC560D30L3 device using Discovery kit (I have replaced SPC560D40 with SPC560D30 MCU). I am trying to implement a state machine using different states of ADC driver. If my understanding is correct, I shall access the states as below,
switch (ADCD2.state)
case ADC_UNINIT:
break;
case ADC_STOP:
break;
case ADC_READY:
break;
case ADC_ACTIVE:
break;
case ADC_COMPLETE:
break;
case ADC_ERROR:
break;
If above way is correct the statement 'ADCD2.state' itself is not working! Can anybody clarify the issue? What other settings are required?
Thanks in advance for your help.
Mike.
#adc
Erwan YVIN
Apr 29, 2015 11:42 AM UTC
Posted on April 29, 2015 at 13:42
Hello Mike ,
Could you try to increase the priority of your EIRQ17 (PSR to set) ?
we have a ADC priority
#define SPC5_ADC_ADC0_WD_PRIORITY           12
#define SPC5_ADC_ADC0_EOC_PRIORITY          SPC5_ADC_ADC0_WD_PRIORITY
if the problem persists , could you send me your application ?
  Best regards
Erwan
