prashanth.mohan22
May 9, 2019 2:27 PM UTC
SPC560B54 FlexCAN bootloader
Actually now I'm working on the FlexCAN boot operation and I have few queries to be addressed to start over.
  1. I have this rudimentary question for an embedded engineer, sorry for it. how do I know the code length/size of my software?
  2. while pushing code on SRAM via FlexCAN boot, what should be the register value for PCONFx registers?
  3. In the 3rd step of FlexCAN boot sequence, how do I push my software to the SRAM? Please help me with the files or process or the sequence in which the code has to be pushed serially in CAN ID 0x013
Thanks for your time in advance.
Best Regards,
Prashanth Mohan
    Erwan YVIN
    Erwan YVINBest answer
    May 14, 2019 12:08 PM UTC
    Hello ,
    You can find in the Reference Manual or in the SPC5Studio Tools suite
    Best regards
    Erwan
    prashanth.mohan22
    May 10, 2019 9:32 AM UTC
    My idea here is to flash SPC board directly via CANH, CANL pins.
    Erwan YVIN
    May 14, 2019 9:01 AM UTC
    Hello ,
    1) It should be the size of out.bin
    You can use this command to check the size of each functions
    ppc-freevle-eabi-nm.exe -S -C --size-sort out.elf
    400aa030 00000242 T vector52
    400b0bb0 000002e2 T FlashCheckStatus
    400ae050 000002f6 T can_lld_transmit
    400af9c0 0000048c T spc_clock_init
    400aed40 000005ee T updater_getData
    400acb60 0000071c t can_lld_l1_handler
    400ac3a0 000007b4 t can_lld_l0_handler
    400ad360 00000c38 T can_lld_start
    Which device do you use ?
    3) to push your software in SRAM , you have to update the linker file.
    For your information , we have some bootloader example by CAN in SPC5Studio Tools suite
    SPC58ECxx_RLA Bootloader Application for Discovery
    Best regards
    Erwan
    prashanth.mohan22
    May 14, 2019 9:23 AM UTC
    Hi Erwan,
    Very thanks for your response, I'm using SPC560B-DIS board. Do we have Bootloader Application for Discovery for SPC560Bxx??
    Regards,
    Prashanth
    prashanth.mohan22
    May 14, 2019 10:03 AM UTC
    Hi @Erwan YVIN​,
    where can I find the elf analysis tool? say ppc-freevle-eabi-nm.exe that you have mentioned in your response
    Prashanth
    Erwan YVIN
    May 14, 2019 11:27 AM UTC
    Hello ,
    You can find the useful in the following directory :
    c:\SPC5Studio\eclipse\plugins\com.st.tools.spc5.tools.gnu.gcc.ppcvle.win32_4.9.4.xxxxx\toolchain\bin\
    Best regards
    Erwan
    prashanth.mohan22
    May 14, 2019 10:51 AM UTC
    Hi @Erwan YVIN​ ,
    Do we have any application note, or flow chart for SPC560B series on bootloader implementation to better understand the generated code?
    Prashanth
    Erwan YVIN
    Hello ,
    Best regards
    Erwan
