sjpatel19922
Feb 28, 2017 2:47 PM UTC
SPC5 Studio - Doesn't seem to be working correctly
Posted on February 28, 2017 at 15:47
Hi, when I create a new project in SPC5 studio, its not showing me with the component initialization options. It does not present me with any options for choosing the microcontroller, configuring the clocks, etc. Please see the attached picture(SPC5)
When I select the microcontroller using the pin map wizard, I am able to configure pins, but it does not seem to be generating any application code.  Please see the attached picture( SPC5_pinmap)
Also, what is the latest released version of SPC5 studio? I have seen post here mentioning the version 5.2.3 being available. My application is still on version 5.0. Its showing 'no updates found in the available software sites' when checking for updates.
#spc5-studio
    Erwan YVIN
    Erwan YVINBest answer
    Mar 3, 2017 10:06 AM UTC
    Posted on March 03, 2017 at 11:06
    Hello ,
    There is a help section in SPC5Studio for SPC5Studio Wizard and screenshot associated
    you can go in 'SPC5Studio Wizard' not 'SPC5 C/C++ Application'
    we have a lot of xamples for differents boards
       Best regards
                    Erwan
    Erwan YVIN
    Feb 28, 2017 3:58 PM UTC
    Posted on February 28, 2017 at 16:58
    Hello 123.abc ,
    you have forgotten to add some components in the configuration.xml
                 Best Regards
                              Erwan
    sjpatel19922
    Feb 28, 2017 5:12 PM UTC
    Posted on February 28, 2017 at 17:12
    Hello Erwan, can you show me an example? Not sure if I am doing it right. I can add components, but its not really doing much. If I click on configuration, it brings the ''Application Configuration'' page. See picture below. 0690X00000606RvQAI.png
    Erwan YVIN
    Mar 2, 2017 10:05 AM UTC
    Posted on March 02, 2017 at 10:05
    Hello ,
    You can use the application wizard (cf help section)
    you can import some application examples via Application Wizard
                 Best Regards
                                Erwan
    Erwan YVIN
    Hello ,
       Best regards
                    Erwan
