jmary
Apr 17, 2025 3:42 AM UTC
Setup Output Pin for SPC582B PWM Emios
I want to generate pwm signal with spc582B with out the signal directly to pin emios0 channel 11 (uc11 pin).
Already use the pwm Icu sample project. With channel 11 out, so I use group 1. When running, the periode callback is working, but still no out in the emios0 channel 11 pin.
How to properly configure pin signal of the pwm?
