pentti2
Jul 10, 2013 8:56 AM UTC
Set up ADC triggered by CTU with Tresos on SPC56EL46
Posted on July 10, 2013 at 10:56
I am trying to configure the ADC to be triggered by the CTU.
But using a debugger I can see, that many of my configurations made in Tresos are not taken over to the �C registers.
As far as I can see the ''init'' code parts are executed as long as  ADC_ResultsBufferPtr[] inside the genrated file Adc_Cfg.c contains NULL_PTR.
Sadly I am not able to find the correct setting to get some values in ADC_ResultsBufferPtr[].
How do I get rid of the NULL_PTR entries.
#spc56
    Luca RODESCHINI
    Nov 19, 2013 5:52 PM UTC
    Posted on November 19, 2013 at 18:52
    Thanks for your post.
    can you please:
     1) share what is the exact part number you are using (SPC56EL46 is not an ST valid part number - you can read on component marking)
    2) send us MCU and ADC configuration files you are currently using.
    thanks
    Luca
