Bastien1
RX interrupt with Runtime-IO
  • March 18, 2021
  • 1 reply
  • 997 views
I would like to know if it possible to make RX interrupt with the serial driver initialize thanks to Runtime-IO Component RLA ?
In reality, I want to use scanf() with interrupt to make it non-blocking.
Thank you by advance
Respectfully
Bastien
    Best answer by Erwan YVIN
    Hello bastien ,
    Did you asynchronous mode in Runtime -IO ?
    In this particular case , often, in some big projects , i am using some multi-threads with real time os (FreeRTOS, chibios ..) in order not to block during scanf process.
    Best Regards
    Erwan
    Erwan YVIN
    Erwan YVINBest answer
    Hello bastien ,
    Best Regards
    Erwan
