zeke.huang
Jun 26, 2019 9:41 AM UTC
Rx can't receive data
Hi all,
Could you check this problem for me? It can not received information from canoe, data(from transceiver) already reached RX pin of SPC5.​
The data transmit from Conoe is : ​
The source code in Attachment.
​I use external OSC is 8M.
CanBitRate is 500 kbps.
Thank you very much.
    Erwan YVIN
    Erwan YVINBest answer
    Jun 28, 2019 9:15 AM UTC
    Hello ,
    Maybe you should debug the Rx Part by using PLS UDE debugger.
    or contact your local FAE.
    I have not the environment in order to reproduce the issue.
    Best regards
    Erwan
    Erwan YVIN
    Hello ,
    Best regards
    Erwan
    zeke.huang
    Jul 1, 2019 6:55 AM UTC
    Hi ​Erwan,
    Thank you for your reply.
    The problem and the solution is that the circuit on the TX side is not connected.
    Best regards
    Zeke​
