Jun 15, 2026 11:28 AM UTC
Request for Technical Support Assets: SPC560Dxx_RLA PIT WINDRIVER and 56xx_flash.dld
Dear Sir/Madam,
I hope this email finds you well.
I am currently working on the development and integration of the ECU project using the SPC5Studio environment and the Wind River Diab Compiler (v5.9.4). During the build configuration and linker script optimization for the SPC56 platform, we have identified a need for specific integration assets.
Could you please provide the following files to assist us in completing our toolchain setup:
  1. SPC560Dxx_RLA PIT WINDRIVER.zip: Required for the PIT (Periodic Interrupt Timer) driver configuration and OS abstraction alignment with the Diab compiler.
  2. 56xx_flash.dld: The specific Linker Definition File (LDF) optimized for the Wind River Diab toolchain to ensure correct memory mapping and flash sectoring.
These files are critical for resolving current build-time linker errors and ensuring compatibility between the RLA (Runtime Lightweight Abstraction) components and our compiler version.
Thank you in advance for your assistance. I look forward to your prompt response.
Best Regards,
Babak
Jun 25, 2026 12:53 PM UTC
Do you try AN5171 Application note Windriver support on SPC5Studio?
Jun 27, 2026 6:22 AM UTC
We had to modify the *.s startup/assembly files in order to make the project compile successfully with Wind River Diab v5.9.4 in SPC5Studio. The build now completes, but the microcontroller does not run correctly and remains continuously in break state after reset.
This suggests there is still a startup/linker or initialization mismatch, and we would appreciate the exact SPC560Dxx_RLA PIT WINDRIVER.zip and 56xx_flash.dld assets for our target configuration.
