VKuma.18
Mar 8, 2022 11:28 AM UTC
Read UART Data on interrupt in SPC5 controller.
how to use UARTto receive data on interrupt instead of using this api (sd_lld_read) as this works in blocking mode in while loop.
Micro is SPC560P50L3.
Is there is an example to use the Uart Rx on interrupt.
As we use this method in Stm32.
Erwan YVIN
Erwan YVINBest answer
Mar 17, 2022 2:25 PM UTC
Hello ,
I recommend you to use some multi-threads mecanism in some RTOS FreeRTOS-RLA or Chibios-HAL.
Otherwise , you need to redevelop sd_lld_read UART Driver
Best Regards
Erwan
Erwan YVIN
Hello ,
Best Regards
Erwan
Apr 18, 2022 6:02 AM UTC
Hello
Is there any other methods to enable uart interrupt? Like using IRQs or ...?​
