Aranj.1
Jun 7, 2021 12:55 PM UTC
PWM period in spc560b54
How can i adjust PWM period in SPC560b54 using spc5 studio wizard?
system clock=32MHZ
peripheral clock=16MHZ
eMIOS0 Global prescaler=20
eMIOS0 pwm counter Bus=counter_bus_A
in eMIOS0 CH23 counter BUS settings:
prescaler=1
period=?
For period 400KHZ, How can i select period in eMIOS0 CH23 counter BUS settings?
    zambrano.luigi
    zambrano.luigiBest answer
    Jun 7, 2021 3:15 PM UTC
    the eMIOS modules are clocked by the periph_set3_clk. The clock in input to each eMIOS channels is periph_set3_clk/GPRE where the GPRE is the global prescaler. Each channel has an internal prescaler. So, the counter of each prescaler is clocked by (periph_set3_clk/GPRE)/(inernal prescaler). If you select in the eMIOS graphic interface a period = N, this means that eMIOS frequency will be ((periph_set3_clk/GPRE)/(inernal prescaler))/N.
    Regards,
    Luigi
    zambrano.luigi
    Regards,
    Luigi
