pratibha soni
Nov 23, 2017 8:56 AM UTC
PWM generation with PSC560B54L5
Posted on November 23, 2017 at 09:56
I want to generate PWM with channel 1,2. I saw the PWM example but it is for channel zero, what are the changes required for channel 1 and channel 2.
#pulse-width-modulation-with-diffrenet-channel.
    Erwan YVIN
    Erwan YVINBest answer
    Nov 23, 2017 10:06 AM UTC
    Posted on November 23, 2017 at 11:06
    Hello Soni ,
    If you use RLA drivers ,  you can change the configuration (cf screenshot)
    Do not forget to generate after saving your configuration.xml
           Best regards
                     Erwan
    Erwan YVIN
    Hello Soni ,
           Best regards
                     Erwan
    pratibha soni
    Nov 23, 2017 10:32 AM UTC
    Posted on November 23, 2017 at 11:32
    Hi Erwan,
    thanks but want more info because I already set the channel configuration but in this channel callback also required? in  for channel 1 and 2 ??whether I am using 0,1,2 or in ch 0 default callback is there.
    Erwan YVIN
    Nov 23, 2017 3:55 PM UTC
    Posted on November 23, 2017 at 15:55
    Hi Soni ,
    No callback is required
             BR
                      Erwan
    pratibha soni
    Nov 23, 2017 5:18 PM UTC
    Posted on November 23, 2017 at 17:18
    Only changes in configuration.xml or nothing else... Even not in code too??
    pratibha soni
    Nov 24, 2017 4:44 AM UTC
    Posted on November 24, 2017 at 05:44
    will be like this?
    for channel 0
    pwm_lld_enable_channel(&PWMD5, 0, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 5000), 0);
    for channel 1
    pwm_lld_enable_channel(&PWMD5, 1, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 5000), 0);
    for channel 2
    pwm_lld_enable_channel(&PWMD5, 2, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 5000), 0);
    waiting for reply.
