RatheeshT
Mar 31, 2021 1:44 PM UTC
Procedure to receive data from UART with ISR mode in SPC560P50L5?
Hi Technical team,
Hardware Environment : SPC560P50L5
I am using example program 'SPC560Pxx_RLA SERIAL Test Application for Discovery'
I am able to transmit data to console window by using above example (using UART).
I dont know , how to use this example for receiving data through UART.
Can you guide me support to receive data from UART with ISR ?
Can you give me Application note for UART receive ?
How can i use existing API?
    Erwan YVIN
    Erwan YVINBest answer
    Jun 3, 2021 9:27 AM UTC
    Hello Ratheesh ,
    You are using a SPC560P discovery board.
    you can plug a chip on your LIN1RX/LIN1TX and keep LIN0RX/LIN0TX for serial print.
    (cf Discovery Kit document)
    a lot of student projects are using it.
    Best Regards
    Erwan
    Erwan YVIN
    Hello Ratheesh ,
    Best Regards
    Erwan
