nooshin_1382
Aug 12, 2015 9:01 AM UTC
Problem with Lin Enable filters
Posted on August 12, 2015 at 11:01
Hi
I Have 2 problems with Lin :
1.When i Recive a data from LIN I have  No interrupt
2.When i want to set a filter in LIN the programm not work at this point in the attachment code :
LINFLEX_1
.IFMR.B.IFM=1;
LINFLEX_1.IFER.R=0;  I attach my code .
Best Regards
Nazerian Vanima
    Erwan YVIN
    Aug 17, 2015 9:46 AM UTC
    Posted on August 17, 2015 at 11:46
    Hello Vanima ,
    I am checking your code , today
    Best regards
                   Erwan
    Erwan YVIN
    Aug 17, 2015 1:55 PM UTC
    Posted on August 17, 2015 at 15:55
    Hello Vanima ,
    On B Devices : you can not access to these registers on LINFlex_1
    LINFLEX_1.IFMR.B.IFM=1;
    LINFLEX_1.IFER.R=0;
    If you want to use the filter mode,you have to use the LinFlex_0. (cf chapter 2), 16 identifier filters for autonomous message handling in Slave mode. (q.) Only LINFlex0 supports slave mode. Best regards Erwan
