ANaze.1
Jan 2, 2020 9:54 AM UTC
Problem in osalThreadDelayMilliseconds function inSP560B50L5
When I use the osalThreadDelayMilliseconds(200) function the software always remain in this loop
while (osalsystime < current + ticks)
i check the software is only LED blink
can any one know what happen to the OSAL library ?
I use RLA Library
    Erwan YVIN
    Erwan YVINBest answer
    Jan 14, 2020 4:07 PM UTC
    Hello Anaze ,
    Did you use some examples ?
    or did you create your own application ?
    The Program is stuck in your loop while because the tick is not incremented
    Check your PIT configuration
    Best regards
    Erwan
    Erwan YVIN
    Hello Anaze ,
    Best regards
    Erwan
