alfierinicola
May 27, 2014 8:43 AM UTC
Problem importing example project
Posted on May 27, 2014 at 10:43
Hi, I downloaded example software SPC56EL and successfully imported all of them but then i can't get them compiled.
I don't know how to set current toolchain and current builder, keeps giving me make error about object files.
Thanks for the help!!
    Erwan YVIN
    May 27, 2014 9:12 AM UTC
    Posted on May 27, 2014 at 11:12
    Hello Nicola222,
    Could you confirm SPC5Studio used version (3.0.0 or 2.0.0) ?
    Anyway , normally the toolchain is present inside SPC5Studio development environment.
    When you import some examples you should use ''internal'' SPC5Studio Application wizard.
    (Cf Screenshot)
    Could you copy-paste your error log ?
    Best Regards
    Erwan YVIN
    ________________
    Attachments :
    2014-05-27_110945.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qWro&d=%2Fa%2F0X0000000boY%2FcyzEs.bazgqAGj_yDdv_XFTxIgNZ69Ka9EYW7T59f8M&asPdf=false
    alfierinicola
    May 27, 2014 9:38 AM UTC
    Posted on May 27, 2014 at 11:38
    I'm using SPC5studio 2.0!
    When I create new Application Components folder is missing in the project so that inclusion is unresolved ad i have to add it manually.
    The screenshot is made importing example project!
    ________________
    Attachments :
    Immagine.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qXBB&d=%2Fa%2F0X0000000bof%2FxZk8J_fP6uX1QxV17Hb2cZLyMS94CvPLmwguDJlPOZE&asPdf=false
    Erwan YVIN
    May 27, 2014 2:29 PM UTC
    Posted on May 27, 2014 at 16:29
    Hello Nicola ,
    it should be ok to add manually.
    Have you tried to build an application from the repository ?
    New ==> SPC5Studio Wizard
    Could you try the last version of SPC5Studio ?
    3.0 is out since yesterday.
    http://www.st.com/web/en/catalog/tools/PF255702#
    for your information,
    To set the toolchain has no impact in C/C++ Build of the project properties
    SPC5Studio is using its own toolchain (gnutools)
    and Hightec compiler (ppc-vle-gcc)
    Best Regards
    Erwan Yvin
    ________________
    Attachments :
    2014-05-27_150920.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qWIZ&d=%2Fa%2F0X0000000boB%2F5.PwUBEbZPmeeHeE__Ad0Hwwl4baz46Y79lkQ1dazQU&asPdf=false
