philipp239955_stm1_stmicro
Dec 16, 2015 11:43 AM UTC
PAL Initialization
Posted on December 16, 2015 at 12:43
I am using the PAL Layer to initialize the pins of the SPC560D Discovery. It works very well, but I’m detected an interesting behavior.
During the pal_init function some pins are set to high for 0,132 ms. This can cause some side effects in my application. Is there a way to avoiding this behavior?
kind regards
Philipp
    Erwan YVIN
    Dec 18, 2015 10:23 AM UTC
    Posted on December 18, 2015 at 11:23 Hello Philipp , could you try others ''advanced'' settings in the configuration ? you can check the function
    void
    _pal_lld_init(
    const
    PALConfig *config) {
    and use the SPC5Studio patch mode to customize. Best Regards Erwan
