paolo2
Sep 30, 2014 12:45 PM UTC
out.elf: cannot generate out.elf - Build command doesn't work.
Posted on September 30, 2014 at 14:45
I installed SPC5Studio 3.0.0, and UDE 4.02.05.
When i build a new project clicking on ''build all'' icon, SPC5Studio doesn't generate out.elf file, so i am not able to debug.
I can debug Software examples for SPC56L-Discovery (dowloaded from the site), because they iclude the correct out.elf file, but if i modify a main.c file, then save and build the project, out.elf isn't updated.
Thanks for any useful response.
Best Regards
Paolo Menoni
    Erwan YVIN
    Oct 1, 2014 7:53 AM UTC
    Posted on October 01, 2014 at 09:53
    Hello paolo ,
    it is better to use the Application Wizard to import SPC56L-Discovery application.
    (cf screenshot)
    All the application coming SPC5Studio 3.0 application wizard are up-to-date
    for out.elf issue, UDE can take the hand on the file out.elf. I recommend before building the SW to stop the debugger.
          Best regards
                    Erwan
    Erwan YVIN
    Oct 1, 2014 7:54 AM UTC
    Posted on October 01, 2014 at 09:54
    Here is the screenshot ;)
    BR
    Erwan
    ________________
    Attachments :
    2014-10-01_094357.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qWnD&d=%2Fa%2F0X0000000boX%2FJN014Q1ldSI83iWWWG1WflLBiLQX_lI.Ek849.7cdMk&asPdf=false
    Erwan YVIN
    Oct 1, 2014 9:02 AM UTC
    Posted on October 01, 2014 at 11:02
    Hello Paolo ,
    I have found the issue
    in the link
    http://www.st.com/web/en/catalog/tools/PF259369#
    user.mak is not correct
    you have to replace main.c in U_C_SRC
    # List of all user C source files
    U_C_SRC     = ./main.c
    Sorry for the issue.
    we will correct the application inside.
       Best regards
                      Erwan
    paolo2
    paolo2Author
    Oct 1, 2014 1:13 PM UTC
    Posted on October 01, 2014 at 15:13
    Hello Erwan,
    many thanks for the prompt reply.
    I followed your instruction (i checked user.mak file, and a imported from the application wizard), but build command doesn't work yet.
    SPC5Studio doesn't update Out.elf.
    I have another prolem: when i load the project, ude shows an error, that i attacched to this message.
    Best regards
    Paolo Menoni
    ________________
    Attachments :
    error.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qZ5n&d=%2Fa%2F0X0000000bp6%2F.IBxgOJg6XVm3HDB3ateauJW68Oe_BsNoZoMV1FqfFw&asPdf=false
    Erwan YVIN
    Oct 1, 2014 2:20 PM UTC
    Posted on October 01, 2014 at 16:20
    Hello Paolo ,
    Your debug environment is OK.
    i think that your out.elf is not generated
    it should be present in build directory
    Could you give your console logs ?
    Generation and Build(Cf Screenshot)
    Best Regards
    Erwan
    ________________
    Attachments :
    2014-10-01_161208.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qWDQ&d=%2Fa%2F0X0000000bo7%2FOf7Q8QyJD9bYaz7iFEMTeN4iLhs1BQIffaKK6VxeuHs&asPdf=false
    2014-10-01_161903.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qVAt&d=%2Fa%2F0X0000000bnt%2FgxW0T6BdX9e4WNOa92YN6ZwWyi8acIToIb5hoR.vVFI&asPdf=false
    paolo2
    paolo2Author
    Oct 2, 2014 5:09 AM UTC
    Posted on October 02, 2014 at 07:09
    Hello Erwan,
    I enclosed 3 files.
    stepbystep.pdf: that shows how I imported the project.
    buildall.bmp: that shows what happens if I click on ''build all''.
    aftergenerate.bmp: that shows what happens if I click on ''build all'' after I click on generate application.
    Best Regards
    Paolo Menoni
    ________________
    Attachments :
    afterGenerate.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qZ5s&d=%2Fa%2F0X0000000bp7%2F8zphK406_O8pp5CvioQsvcbcMlLYfO8cjRh4Nr3v7B4&asPdf=false
    buildall.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qZ75&d=%2Fa%2F0X0000000bp8%2F7fk2ZrfmZyf0n7Tqxisv2ZIBIq2bRLjpXJzWLDWJqxU&asPdf=false
    stepbystep.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qYRE&d=%2Fa%2F0X0000000bp0%2FQwYb2apeX1rEdjYP1jONz0qhkSu7T7W_yLEH5svGl8U&asPdf=false
    Erwan YVIN
    Oct 2, 2014 8:31 AM UTC
    Posted on October 02, 2014 at 10:31
    Hello Paolo ,
    The generation is OK.
    The build is KO because of make.exe (PATH Issue).
    you have a CYGWIN installation in your environment.
    Your PATH should have this following content :
    C:\SPC5Studio\eclipse\plugins\com.st.tools.spc5.tools.hightec_1.0.0.201306281422\hightec\ppc-ht-eabi\bin;C:\SPC5Studio\eclipse\plugins\com.st.tools.spc5.tools.hightec_1.0.0.201306281422\hightec\bin;C:\SPC5Studio\eclipse\plugins\com.st.tools.spc5.tools.gnu_1.0.0.201306281422\gnutools;
    could you give your full installation details ?
    Help ==> About SPC5Studio
    Button Installation Details
    and Tab Configuration
    have you updated into SPC5Studio 3.1.9 ?
    Normally , this issue is corrected on SPC5Studio 3.1.9
    Help ==> Install New Software
       Best Regards
                    Erwan
    paolo2
    paolo2Author
    Oct 3, 2014 6:43 AM UTC
    Posted on October 03, 2014 at 08:43
    Hello Erwan,
    as you requested, i attached a file (configuration.txt) in wich i copied my current spc5 studio configuration.
    I attached also a file (installnewsw.pdf): in wich i show my proxy setting, and the step i followed to install new software.the third image, i can
    As you can see in the third image i tested internet connection by using Show View ==> Other ==> Internal Web browser.
    Unfortunately after i had installed, and had restarted, my version was still 3.0.0, consequently build command didn't work.
    According to you should I uninstall, and reinstall?
    Best regards
    Paolo Menoni
    ________________
    Attachments :
    configuration.txt : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qYFw&d=%2Fa%2F0X0000000box%2F3qlt3a9dpqaJ8faqDVhho0Cz_.7VtLDubWjeapRdfsY&asPdf=false
    installnewsw.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qYjc&d=%2Fa%2F0X0000000bp4%2FUFnZxEO2NA0wG8dTgkXTu2Eyp_xWEDuVkgn3c45129E&asPdf=false
    Erwan YVIN
    Oct 3, 2014 7:36 AM UTC
    Posted on October 03, 2014 at 09:36
    Hello Paolo ,
    Your configuration is good.
    you have already the last version of SPC5Studio.
    your version is already up-to-date.
    i am sending to you a document
    Could you follow the chapter 2 ..
    Solution in chapter 2.5 and 2.6.
    if the problem is still present
    i will send an invitation with teamviewer.
    Best Regards
    Erwan
    ________________
    Attachments :
    SPC5Studio_FAQ_configurations_issue_cx389511_1.0_D2.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qYPN&d=%2Fa%2F0X0000000boz%2FcisdUuIjUBo59hEPiowmLowMAlNm58tSYxxUGtPSWZk&asPdf=false
    paolo2
    paolo2Author
    Oct 6, 2014 8:53 AM UTC
    Posted on October 06, 2014 at 10:53
    Hello Erwan,
    I reinstalled spc5studio, and I followed your instructions, but build doesn't work yet.
    I copyed into the eclosed file, the messages spc5studio shows when building.
    Not always I have my laptop with me, and and not always I work on SPC5Studio during busuness hours, so, if you consider it appropiate, could you please let me know when your are available (day and timetable) for a teamviewer session.
    Best regards
    Paolo Menoni
    ________________
    Attachments :
    console.txt : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qUVY&d=%2Fa%2F0X0000000bnl%2FGILhb2Q0hulzIARsZeA95YDl5urhFEav7kPoFGL97PE&asPdf=false
