LBona.2
Apr 22, 2020 2:00 PM UTC
osalThreadDelayMilliseconds not working in spc584-dis
hi during the debug of my program with UDE it gets stuck on osalThreadDelayMilliseconds i found in the forum that the problem may be a PIT configuration problem but i don't know how to set it.
    Erwan YVIN
    Erwan YVINBest answer
    May 5, 2020 12:39 PM UTC
    Hello ,
    Could you send us the PIT configuration ?
    I recommend you to take SPC584Bxx_RLA PIT Test Application for Discovery as example
    Best Regards
    Erwan
    Erwan YVIN
    Hello ,
    Best Regards
    Erwan
    LBona.2
    LBona.2Author
    May 6, 2020 1:31 PM UTC
    i didn't set any particular PIT configuration. I only wanted to put a delay for slower the execution of a function during debugging.
    #include "components.h"
    #include <math.h>
    #include <stdlib.h>
    float u_alfa = -1000;
    float u_beta = -10;
    float Vdc = 600;
    float fsw = 17000;
    char gates[6];
    void spaceVectorMod(float u_alfa,float u_beta, float Vdc, float fsw, char * gates, float tzero);
    int main(void) {
     /* Initialization of all the imported components in the order specified in
     the application wizard. The function is generated automatically.*/
    	componentsInit();
    	float tzero=0;
    	while(true){
    		spaceVectorMod(u_alfa, u_beta, Vdc, fsw, gates, tzero);
    		osalThreadDelayMilliseconds(300);
