kb24
Senior
Mar 24, 2022 1:57 PM UTC
Multicore Processor Interrupt Processing
SPC58EC has one Interrupt Controller which supports two processors. You can give different vector tables for each core. Let's say two cores are active and one external interrupt (ADC, Timer) happened, what will be the process after this? Which core will run the interrupt handler? Thanks in advance.
    ODOUV.1
    ODOUV.1Best answer
    Mar 28, 2022 12:32 PM UTC
    In SPC5Studio, in the External IRQ configurator, you can select the core which will intercept your interrupt:0693W00000LvylPQAR.pngBest regards,
    -Olivier
    ODOUV.1
    ODOUV.1Best answer
    -Olivier
