nooshin_1382
Aug 4, 2015 3:45 PM UTC
Licence Problem for SPC56_DRV_LIN2.1-0.9.5 Lin Driver
Posted on August 04, 2015 at 17:45
Hi
I Download this software for using Lin Driver on SPCStudio But When you want to setup this software , the software need a serial number but i send request to apg tools
but have no response for my request.
i want to use the LIN Driver how can i use the software?
thanks
Nazerian Vanima
    Erwan YVIN
    Aug 5, 2015 1:57 PM UTC
    Posted on August 05, 2015 at 15:57
    Hello Vanima ,
    I am checking with APG Support team.
    Did you use by UART mode ?
    because there is some LIN example configuration in serial_lld.c (SPC5Studio source code)
        Best Regards
                 Erwan
    nooshin_1382
    Aug 8, 2015 9:55 AM UTC
    Posted on August 08, 2015 at 11:55
    Hello Dear Erwan
    Thanks For your response
    No I didn`t set for USART, but i did not see any example if there is an example exist for this LIN issue please send it for me.
    Can i use a Linflex 0 as uart and use other linflex for LIN BUS ?
    Best Regards
    Nazerian Vanima
    Erwan YVIN
    Aug 10, 2015 3:02 PM UTC
    Posted on August 10, 2015 at 17:02
    Hello Vanima ,
    You can use :
    LINFLEX_0 for UART .
    and other LINFLEX_x for LIN.
    there is a good example for UART in SPC5Studio :
    SPC560Bxx OS-Less Test Application for Discovery
    in this case, LIN is configured on UART.
      Best Regards
                   Erwan
