VPAI.1
Jul 16, 2020 3:12 PM UTC
Issue in Flashing the SPC584B- DSM board
Hi Team,
Please help to resolve the issue
Flashing the SPC584B- DISP board failed and end up in the following errors,
Error messages:
 PpcJtagTargIntf: Connection to target lost !
 PpcJtagTargIntf: Failed to reset target system !
 PpcJtagTargIntf: No JTAG client found !
Please check:
- target power supply
- JTAG cable connection
- target configuration
  • This issue has started just after connecting with external LIN device(NeoVI Blue).
  • All indicator LEDs in the board are still glowing.
  • The device is still visible in Device Manager under Ports on connecting with the computer.
  • There is no fluctuation in the current observed.
  • The power is given through regulated power supply keeping maximum current 200mA.
Sudeendra S
    Erwan YVIN
    Erwan YVINBest answer
    Jul 17, 2020 9:10 AM UTC
    Hello Sudeendra ,
    Could you install the PLS drivers located in UDE Folder
    c:\Program Files (x86)\pls\UDE Starterkit 4.10\Driver\JtagUsbDriver\ ?
    Best Regards
    Erwan
    Erwan YVIN
    Hello Sudeendra ,
    Best Regards
    Erwan
    VPAI.1
    VPAI.1Author
    Jul 17, 2020 12:13 PM UTC
    ​Hi Erwan,.
    Thanks allot.Resolved the issue by the suggestion provided.
    Sudeendra s
