swu.1
Sep 29, 2022 12:59 AM UTC
Is Symmetric Multi-Processing (SMP) supported on Stellar SR6 P7 R52+ cores
There are several R52+ cores available in Stellar SR6 P7 line, e.g. SR6P7C8.
I have question about the Symmetric Multi-Processing (SMP) support on these R52+ cores. Is SMP available inside R52+ cluster or among R52+ clusters?
    FSPIL
    FSPILBest answer
    Oct 23, 2025 4:15 PM UTC
    SR6 information is provided under NDA.
    For any question, please contact local ST support, and do not post information/questions in this public forum.
    Thank you.
    Best regards,
    Francesco
    Giuseppe DI-GIORE
    Oct 17, 2022 9:16 AM UTC
    SMP is a matter of Operating System.
    SR6P7 devices provides support for SMP Real Time Operating Systems.
    There is no MMU so Linux OS cannot be supported.
    Regards,
    Giuseppe
    swu.1
    swu.1Author
    Nov 21, 2022 9:13 AM UTC
    Thanks Giuseppe,
    SMP require hardware coherent for both CPU/Core, actually I found the atomic operation issue at following page,
    https://community.st.com/s/question/0D53W00001wIF3sSAG/does-cluster-local-ram-support-exclusive-access-with-shareable-attribute-as-well-as-noncacheable
    Do you have any idea?
    Oct 1, 2024 2:07 PM UTC
    Hello @swu.1 ,
    Did you get it to use SMP?
    Best regards.
    FSPIL
    FSPILBest answer
    Thank you.
    Best regards,
    Francesco
