Alexey Potyomkin
Jan 22, 2017 11:34 AM UTC
Initialization MCU
Posted on January 22, 2017 at 12:34
Good day. This my first application on spc5 studio. I add for testing one led on Port B[1] to board witch MCU SPC560P40L3. I add in generate main.c file one sting -pal_setpad(PORT_B, LED_RED);. Pin will add pin-list, and adjust Clock timing for osc=8000000 Hz.
Afte download outfile out.hex to MCU and start application-pin not state low or hich. Pin state Z(hich impedance).
I need help
to make the right initialization MCU. I try other test application. Not working.
Best regards.
    Erwan YVIN
    Erwan YVINBest answer
    Jan 24, 2017 10:34 AM UTC
    Posted on January 24, 2017 at 11:34
    Hello Alexey ,
    Welcome to SPC5Studio world ;)
    i think that your clock configuration is not correct.
    Do you use SPC560Pxx Discovery Board or SPC56Pxx Motherboard and Minimodule
    There is some Test Applications examples for these 2 Hw (RLA & HAL) in the application wizard.
    You can import them by using the magic stick cf screenshot
       Best Regards
            Erwan
    Erwan YVIN
    Hello Alexey ,
       Best Regards
            Erwan
    Alexey Potyomkin
    Jan 29, 2017 6:49 PM UTC
    Posted on January 29, 2017 at 18:49
    Thanks. Solved. Select HAL confuguration, selekt not init, manualy configurating clocking module, editing hal_lld.c
