PIndr.2
May 31, 2023 11:50 AM UTC
I want to know how to change the white theme to a dark theme in SPC5Studio.
Is it possible to change the white theme to a dark theme in SPC5Studio?
    Peter BENSCH
    May 31, 2023 12:18 PM UTC
    This should be possible, please check and try this thread.
    Hope that helps?
    /Peter
    PIndr.2
    PIndr.2Author
    May 31, 2023 12:39 PM UTC
    Dear Peter,
    Can you please give me directions to change the dark theme?
    Pasindu
    Peter BENSCH
    May 31, 2023 1:16 PM UTC
    OK, maybe the information at the link provided is not sufficient.
    In fact you just need to install Devstyle, which has been discussed very often here in the Community - just search for Devstyle.
    Devstyle requires the installation of Oxygen:
    Then try installing DevStyle and check if it installs fine: Help > Eclipse Marketplace --> Devstyle
    Good luck!
    /Peter
