Bwang.3
Apr 21, 2023 2:12 PM UTC
I installed SPC5Studio software, but the Clock tree cannot be displayed!
Even after restarting the computer, it won't work, and even if the software is reinstalled, it won't work!
ODOUV.1
Apr 21, 2023 2:57 PM UTC
the graphical clock tree is not existing on all SPC5xx devices, which SPC5 MCU do you use ?
Best Regards.
Bwang.3
Bwang.3Author
Apr 21, 2023 3:13 PM UTC
I am using SPC560P MCU !
Bwang.3
Bwang.3Author
Apr 21, 2023 3:12 PM UTC
ODOUV.1
We do not have graphical clock tree for these 3 products:
SPC572Lxx
SPC574Sxx
SPC58xExx
But you can configure with the textual clock component:
Bwang.3
Bwang.3Author
Apr 21, 2023 3:24 PM UTC
ODOUV.1
Apr 21, 2023 3:35 PM UTC
_legacyfs_online_stmicro_images_0693W00000biatwQAA.pngDo you have same MCU than me ?
ODOUV.1
ODOUV.1
Apr 21, 2023 3:38 PM UTC
would you please:
1) close SPC5Studio
2) erase .log file in C:\SPC5Studio-6.0\workspace\.metadata
3) open SPC5Studio
4) reproduce the issue
5) provide me the new .log file
Bwang.3
Bwang.3Author
Apr 21, 2023 3:43 PM UTC
ODOUV.1
Apr 21, 2023 3:52 PM UTC
it is because you do not display file extension
you have "version.ini" displayed as "version" 1KB
and ".log" displayed as icon 105 KB
please send me the 105 KB file, it is your ".log"
Bwang.3
Bwang.3Author
Apr 21, 2023 4:11 PM UTC
!SESSION 2023-04-22 00:10:39.491 -----------------------------------------------
eclipse.buildId=unknown
java.version=11.0.7
java.vendor=GraalVM Community
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN
Framework arguments: -eclipse.keyring configuration\.eclipse\org.eclipse.equinox.security\secure_storage
Command-line arguments: -os win32 -ws win32 -arch x86_64 -eclipse.keyring configuration\.eclipse\org.eclipse.equinox.security\secure_storage
!ENTRY org.eclipse.core.resources 2 10035 2023-04-22 00:10:43.973
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jface 2 0 2023-04-22 00:11:16.354
!MESSAGE Ignored reentrant call while viewer is busy. This is only logged once per viewer instance, but similar calls will still be ignored.
!STACK 0
java.lang.RuntimeException
at org.eclipse.jface.viewers.ColumnViewer.checkBusy(ColumnViewer.java:764)
at org.eclipse.jface.viewers.ColumnViewer.update(ColumnViewer.java:543)
at org.eclipse.ui.navigator.CommonViewer.update(CommonViewer.java:515)
at org.eclipse.jface.viewers.StructuredViewer.update(StructuredViewer.java:1976)
at org.eclipse.ui.internal.navigator.resources.nested.NestedProjectsLabelProvider.lambda$2(NestedProjectsLabelProvider.java:87)
at java.base/java.util.concurrent.CompletableFuture$UniAccept.tryFire(CompletableFuture.java:714)
at java.base/java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:506)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.run(CompletableFuture.java:1705)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.exec(CompletableFuture.java:1692)
at java.base/java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:290)
at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(ForkJoinPool.java:1020)
at java.base/java.util.concurrent.ForkJoinPool.scan(ForkJoinPool.java:1656)
at java.base/java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1594)
at java.base/java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:177)
!ENTRY org.eclipse.ui 4 0 2023-04-22 00:11:26.410
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: 缺少对象
at org.eclipse.swt.browser.WebBrowser$EvaluateFunction.function(WebBrowser.java:195)
at org.eclipse.swt.browser.WebSite.Invoke(WebSite.java:809)
at org.eclipse.swt.browser.WebSite$7.method6(WebSite.java:182)
at org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMObject.java:120)
at org.eclipse.swt.internal.ole.win32.COM.VtblCall(Native Method)
at org.eclipse.swt.internal.ole.win32.IDispatch.Invoke(IDispatch.java:65)
at org.eclipse.swt.ole.win32.OleAutomation.invoke(OleAutomation.java:575)
at org.eclipse.swt.ole.win32.OleAutomation.invoke(OleAutomation.java:538)
at org.eclipse.swt.browser.IE.execute(IE.java:1202)
at org.eclipse.swt.browser.WebBrowser.nonBlockingExecute(WebBrowser.java:400)
at org.eclipse.swt.browser.WebBrowser.evaluate(WebBrowser.java:450)
at org.eclipse.swt.browser.WebBrowser.evaluate(WebBrowser.java:406)
at org.eclipse.swt.browser.Browser.evaluate(Browser.java:684)
at org.eclipse.swt.browser.Browser.evaluate(Browser.java:631)
at com.st.tools.spc5.wizards.engine.ui.editors.WizardsEnginePage$4.completed(WizardsEnginePage.java:496)
at org.eclipse.swt.browser.IE.lambda$6(IE.java:656)
at org.eclipse.swt.ole.win32.OleEventTable.sendEvent(OleEventTable.java:58)
at org.eclipse.swt.ole.win32.OleEventSink.notifyListener(OleEventSink.java:160)
at org.eclipse.swt.ole.win32.OleEventSink.Invoke(OleEventSink.java:128)
at org.eclipse.swt.ole.win32.OleEventSink.access$1(OleEventSink.java:105)
at org.eclipse.swt.ole.win32.OleEventSink$1.method6(OleEventSink.java:79)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(Native Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3522)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1160)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1049)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
ODOUV.1
Apr 21, 2023 4:21 PM UTC
Thank you I will ask an expert to analyze your LOG
ODOUV.1
Do you have same issue with another Device ? SPC582B for example
Bwang.3
Bwang.3Author
Apr 21, 2023 4:27 PM UTC
If you open the SPC5Studio software and don't connect it to the development board using USB, shouldn't this be the problem?
ODOUV.1
Apr 21, 2023 4:46 PM UTC
no need a board to configure a project and compile it
ODOUV.1
Apr 21, 2023 4:47 PM UTC
Thank you , so it is on all MCUs on your side
We will contact you when your LOG would have been analyzed
Best Regards
Aug 19, 2024 12:44 PM UTC
Any update on how to display the clock tree ?
