LHong.11
Feb 21, 2022 5:58 AM UTC
How to USE SPC58x MCU to generate PWM waveform up to 50Mhz
Hi guys.
I am evaluting SPC58x  serials MCU to toggle GPIO pin to generate 101010 data pattern.
It should be meet 50MHz (or 100Mbps).
can it come ture?
    Giuseppe DI-GIORE
    Feb 27, 2022 10:08 PM UTC
    Have a look at SPC58NN, with GTM running at 200 MHz and ATOM/TOM divider set to 4
    please see also the datasheet and the pinout description, only pin with strong/very strong
    configuration can reach 50 MHz.
    However it is at upper bound limit of pad specification.
