Yali Mobilities
Feb 24, 2021 12:27 PM UTC
how to select and unselect DSPI slave select lines
while using the DSPI example in spc58ec_disp , i couldn't see that the "spi_lld_select" and "spi_lld_unselect " functions usage to control the slave pin. and it didn't had any effect while i used the functions. how could i use the functions to control the chip select line.
    zambrano.luigi
    zambrano.luigiBest answer
    Feb 25, 2021 7:12 AM UTC
    if the DSPI is configured in Slave mode, its Chip Select (and Clock) must be driven by a DSPI master.
    Regards,
    Luigi
    zambrano.luigi
    Regards,
    Luigi
