$AK
Apr 20, 2021 6:15 AM UTC
How to program SPC560B50L5 MCU
Using SP560B50 MCU, but programming the IC is the complex part.
We used SPC560B54-DIS board to program the B50 IC, but the DIS board repeatedly fails with FDTI driver issue.
Kindly suggest any other programmer or way to program them.
Regards,
AK
    Erwan YVIN
    Erwan YVINBest answer
    Jun 3, 2021 8:47 AM UTC
    Hello ,
    maybe you can use JTAG connector.
    have you solved your issue ?
    Best Regards
    Erwan
    Erwan YVIN
    Hello ,
    Best Regards
    Erwan
