aurelien23
Dec 9, 2020 4:01 PM UTC
How to measure the stack remaining available size
I had to enhance the stack size using __process_stack_size__ value to make my software running and I would like to know how to measure the stack remaining size. I tried commenting out the ram init in boot.s and fill the stack ram area with a 0x55AA pattern using the debugger, but the area is still initialized. Is there an easy way to know the stack occupied size??
    Giuseppe DI-GIORE
    Jan 12, 2021 11:12 PM UTC
    indeed stack occupied size depends on the application.
    A simple way to know, at runtime if a stack allocated variable is still inside the defined stack memory is:
    1. get the address of the variable
    2. compare it with the top of the stack (note that the stack grows downward)
    In sPC5Studio top of the stack is defined in the linker script file (__core0_process_stack_base__)
    Also: PowerPC ABI defines R1 register as stack pointer. It can be used to know the occupied stack size by doing:
    • (content of R1) minus (__process_stack_end__)
    __process_stack_end__ is defined in linker script.
    In SPC5Studio crt0.s file, R1 is initialized with address of __process_stack_end__
    Regards,
    Giuseppe
    PS: unfortunately [PowerPC] FreeGCC compiler does not support -stack-protector option.
    Giuseppe DI-GIORE
    Regards,
    Giuseppe
