Pradnya
Mar 19, 2020 11:49 AM UTC
How to generate UART RX INTERRUPT WITH SPC560PXX
Hello All,
I am working on UART on SPC560p Discovery board. I can transmit the data but unable to receive the data. I want to receive byte by interrupt method to avoid blocking.
Please guide me with Rx interrupt initialization so that I can use
"static void spc5xx_serve_rxi_interrupt(uint32_t isdp)" function given in "Serial_iid.c"
Also please suggest me if any other method to receive the data without blocking.
Thank You,
Pradnya
    Erwan YVIN
    Erwan YVINBest answer
    Mar 31, 2020 1:30 PM UTC
    Hello ,
    You have to enable LInFlex 0 Low Level Drivers
    you already support interrupt method in our driver
    please follow example serial application
     * @brief  LINFlex-0 RXI interrupt handler.
     * @isr
    IRQ_HANDLER(SPC5_LINFLEX0_RXI_HANDLER) {
     IRQ_PROLOGUE();
     LinflexD1.rxi_lincallback(LinflexD1.device);
     IRQ_EPILOGUE();
    Best regards
    Erwan
    Erwan YVIN
    Hello ,
     * @isr
     IRQ_PROLOGUE();
     IRQ_EPILOGUE();
    Best regards
    Erwan
