User.100
Nov 16, 2022 4:21 AM UTC
how to found out any printf function for debug messages?
I use SPC5Studio-5.8.1, and SPC574S MCU, but I can not found any printf funciton example in the serial example code. Would you help me?
    Nov 16, 2022 5:48 AM UTC
    If using GNU/GCC wouldn't the STDIO plumbing come out via _write() ?
    Implement output to a UART you've initialized for this purpose. ​
    User.100
    User.100Author
    Nov 16, 2022 5:51 AM UTC
    Thank you for your answer. would you give me some more information.
    where can I found the  via _write() ?
    Nov 16, 2022 5:59 AM UTC
    Check or Google newlib/syscalls.c
    User.100
    User.100Author
    Nov 16, 2022 6:50 AM UTC
    Hi Tesla,
    I don't found any useful information in search newlib/syscalls.c.
    and I found that SPC5Studio can not found the file of "newlib/syscalls.c".
    so do you have any other suggestion?
    Giuseppe DI-GIORE
    Nov 17, 2022 3:48 PM UTC
    SPC5Studio provides a component called "Runtime I/O" which implements the low lever software to enable printf().
    Add "Runtime I/O" component to your project, configure it (which seria port to use) and use printf().
    User.100
    User.100Author
    Nov 18, 2022 2:39 AM UTC
    Hi Giuseppe DI-GIORE,
    Thank you for your reply. I don't know how to add ​"Runtime I/O" component to my project.
    Would you give me a example? I searched "Runtime I/O" in serial enabled project , but found nothing.
    Giuseppe DI-GIORE
    Nov 18, 2022 9:56 AM UTC
    Select a Platform Component (right click)
    0693W00000WIn3NQAT.pngThen select Runtime I/O component
    Giuseppe DI-GIORE
    Dec 12, 2022 8:45 AM UTC
    Configure the serial port using the Low/Level Driver component (selecting the pin you need) and the select the just configured serial port in the Runtime I/O component.
