Angle
Aug 11, 2022 3:09 AM UTC
How to enable the FlexPWM driver setting based on the pwm pin configuration on spc5 board?
Hi, can anyone explain to me about this FlexPWM driver?
What is SM0 stand for? and how i can set the driver based on pin configuration? i did not understand about this setting.
Let say i want to configure pin on PORT_E[5] which is PWM_0/A1_0. So, in this setting which one i need to tick to enable the driver?
    ODOUV.1
    ODOUV.1Best answer
    Aug 12, 2022 8:04 AM UTC
    I was confused too before to look at the PWM block diagram in the reference manual.
    Please open the RM and look to Figure 419. PWM Block Diagram
    Best regards
    ODOUV.1
    Aug 12, 2022 7:50 AM UTC
    assuming that your MCU version is a SPC574S
    and looking into the corresponding reference manual (motor control -> FlexPWM):
    https://www.st.com/resource/en/reference_manual/rm0387-spc574sx-32bit-power-architecture-microcontroller-for-automotive-asild-applications-stmicroelectronics.pdf
    it seems that SM0 stands for SubModule0 of a PWM module
    In your case, using pin Port_E[5] , the A1_0 configuration is linked to the SM1 of PWM0
    So in SPC5Studio, you need to enable at least FlexPWM0 SM1:
    0693W00000QNYckQAH.pnghen it will enable the driver FLEXPWMD2:
    Best regards
    Angle
    AngleAuthor
    Aug 12, 2022 8:00 AM UTC
    Okay then may i know how i can recognize whether it its SM0, SM1, SM2 or SM3? I got confuse for this SM0, SM1, SM2, SM3
    ODOUV.1
    ODOUV.1Best answer
    Best regards
