DPate.1133
Jun 24, 2020 9:24 AM UTC
how to enable JTAG in SPC56EL60?
Hello there,
I want to enable/disable JTAG in SPC56EL60 microcontroller, however i did not found such information in reference manual.
Could you provide clarify how can JTAG can be enabled/disabled from Sw?
    Erwan YVIN
    Jun 25, 2020 3:25 PM UTC
    Hello ,
    You can find some detailed information n the chapter 30 JTAG Controller (JTAGC)
    Which board do you use ?
    Best Regards
    Erwan
    DPate.1133
    Jun 29, 2020 11:00 AM UTC
    Hello Erwan,
    I gone through chapter 30 JTAG Controller , however i did not find any step to activate deactivate jTAG using Sw.
    There are some step mentioned to activate JATG using HARDWARE.
    And i am not using any board , but SPC56EL60 used in our project.
    So could you please provide some info about how to activate/deactivate JTAG using software ? and it is possible to activate using Sw or not ?
    Also by default JTAG in SPC56EL60 will enabled ?
    It will be very helpful for me if you provide your response on this.
    Thanks in advance
    Erwan YVIN
    Jul 2, 2020 8:07 AM UTC
    Hello DPate ,
    Do you use a discovery board , Motherboard + Chip or your own board ?
    Best Regards
    Erwan
    DPate.1133
    Jul 2, 2020 8:17 AM UTC
    Hi Erwan,
    As mentioned in previous reply, i am not using any board, but i am using SPC56EL60 in our own board.
    Could you please clarify the point i mentioned above?
    Also i found only 1 method to activate JTAG , and i think it is not based on Sw. please check attached Snapshot.0693W000001rzq3QAA.png
