Saravanan_Mari
Dec 16, 2020 9:23 AM UTC
How to debug through the j-link segger
Hi everyone we are trying to debug the program in SPC560p dicovery board when we are using the UDE debugger in that we getting some errror which i mentioned below please help us in this regard ,we need configure anything in the UDE debegger
Message from component 'PpcJtagTargIntf' :
Can't connect target !
Failed to open communication channel !
Message from component 'FtdiCommDev' :
Failed to open FTDI device driver !
Message from component 'UDEDebugServer' :
Unable to establish connection . To correct the situation, check configuration file entries and try again.
Kidlt help us in this regard
Thanks in Advance
Saravanan Mariyappan
    Erwan YVIN
    Erwan YVINBest answer
    Dec 17, 2020 3:46 PM UTC
    Hello Saravan ,
    I am not sure that J-LINK Segger is compliant with SPC5 Cores
    you should install :
    https://www.st.com/content/st_com/en/products/development-tools/software-development-tools/spc5-software-development-tools/spc5-udestk-sw.html
    FTDI Chip for the debug is integrated in the discovery board
    Best regards
    Erwan
    Erwan YVIN
    Hello Saravan ,
    Best regards
    Erwan
    Saravanan_Mari
    Dec 18, 2020 5:47 AM UTC
    Thanks for your Response
    We are planning to make the customized Board using the SPC560P50L5 controller for that we need flash the MCU in Our design we are not including the FTDI chip for flashing
    Is there any way to flash the MCU
    Give any suggestions help us in this regard
    Giuseppe DI-GIORE
    Jan 11, 2021 8:19 PM UTC
    SPC560P50L5 supports an alternate mode (than FTDI/JTAG) to load new firmware and flash it.
    This mode is described in Reference Manual [link] section 34 Boot Assist Module (BAM)
    SPC560P50L5 supports:
    • Boot from LinFlex (UART)
    • Boot from FlexCAN (CAN)
    Three pins (PA2, PA3, PA4) are used to select which boot mode should be implemented.
    Regards,
    Giuseppe
