capeter
Mar 25, 2021 3:53 AM UTC
How to configure the trigout signal of the PWM to the TGS module of the CTU module
Requirement: The CTU trigger signal from the PWM output needs to pass through the SIU MUX module and then reach the CTU module.0693W000008xr8wQAA.pngFound problem: When configuring the MSCR registers of the SIU2, I found that the description in the manual does not match the registers specified in the official header file. How do I proceed with this configuration, does the manual prevail or does it?
    Erwan YVIN
    Jun 3, 2021 9:33 AM UTC
    Hello Capeter ,
    could you give me your device used and device number ?
    maybe your RM is not updated
    Best regards
    Erwan
