rpoon
Dec 18, 2019 12:10 PM UTC
How to configure LIN Identifier filter for SPC560B54L5 discovery board .
I am using LIN4 as slave , but I am not able to activate the identifier filter . Actually other than lin driver 0(LD0) , lin identifier filter is not getting activated.
ldp->linflexlp->IFER.R = (uint16_t) (ifer | (((uint32_t)1U << 1))); /* Enable #Filter */
Program is getting stuck in above statement in lin_lld.c->spc5_linflex_set_filter function.
as per the reference manual,
To configure an identifier filter the filter must first be activated by programming IFER[FACT] = 1.
but where exactly we have to make the configuration for activating the filter.
    Erwan YVIN
    Erwan YVINBest answer
    Jan 28, 2020 4:22 PM UTC
    Hello rpoon ,
    Sorry for my late answer.
    your program is stuck in spc5_linflex_set_filter.
    Is it a crash or a data abort,
    Could you check your LR and R14 in assembler mode ?
    Best Regards
    Erwan
    rpoon
    rpoonAuthor
    Jan 24, 2020 4:39 AM UTC
    @Erwan YVIN​
    can you please help me out with above thread.
    Thank you
    Erwan YVIN
    Hello rpoon ,
    Best Regards
    Erwan
    rpoon
    rpoonAuthor
    Jan 29, 2020 5:53 AM UTC
    Hello Erwan,
    I am configuring LIN driver 4 as slave LIN driver 5 as master .
    1. R14 is always 0x00000000
    2. LR value at time of program stuck in set filter is : 0x00001C9E
    I am facing this issue for all LIN channel except LIN driver 0.
    Thank You
    rpoon
    rpoonAuthor
    Jan 31, 2020 5:45 AM UTC
    @Erwan YVIN​
    I am attaching the application code, kindly help me out to identifying whether it is driver issue or I am not initializing properly .
    rpoon
    rpoonAuthor
    Feb 19, 2020 10:05 AM UTC
    Hello @Erwan YVIN​
    would you have any information on this thread?
