Ray1
Aug 9, 2019 10:35 AM UTC
How to configure flex pwm pins for PWMX.
I am working on SPC56xL Discovery+ kit(spc56el70l5) and i'm unable to generate pwm signal on PWMX pins. We are able to generate pwm signals on PWMA & PWMB pins respectively but not on PWMX pins.
    Erwan YVIN
    Aug 14, 2019 12:43 PM UTC
    Hello Ray ,
    Have you checked these application
    SPC56ELxx_RLA PWM-ICU Test Application for DiscoveryPlus in SPC5Studio ?
    It is maybe a configuration issue.
    Best regards
    Erwan
    Ray1
    Ray1Author
    Aug 16, 2019 7:47 AM UTC
    I tried demo application, and also checked the pin configuration. Its not working.
    I am setting PWM driver 1, and channel 2 for Hardware pin 26 (pwmx_0).
    pwm_lld_start(&PWMD1, &pwm_config_pwmconfig);
    pwm_lld_enable_channel(&PWMD1, 2, PWM_PERCENTAGE_TO_WIDTH(&PWMD1, 5000));
    Ray1
    Ray1Author
    Aug 21, 2019 5:19 AM UTC
    Hi Erwan,
    I am unable to generate pwm signal on PWMX pins, can you provide sample code for generating pwm signal on Hardware pin 26 (pwmx_0).
