LJere
Jul 17, 2019 11:04 AM UTC
How to config with CAN bus filter in SPCstudio?
Hi all,
I'm using SPC570S0DISP DEMO Board(SPC570S50E1) to lean how to config CAN's filter.
And the attachment is my config and source code.
In my config,i just want CAN ID 0x112 to interrupt fifo callback function.And then i get the data in callback function. But unfortunatelly,ID 0x112/0x200/0x312/0x400/0x512/0x600/0x712 can interrupt fifo callback also.
So,can anyone help me correct my configuration and explain it?
thanks.
Jer.
    Erwan YVIN
    Erwan YVINBest answer
    Jul 17, 2019 2:11 PM UTC
    Hi ,
    Maybe you should add a filter in your configuration
    Cf Screenshot
    Best regards
    Erwan
    Erwan YVIN
    Hi ,
    Cf Screenshot
    Best regards
    Erwan
    LJere
    LJereAuthor
    Jul 18, 2019 1:09 AM UTC
    Hi Erwan,
    The attachment file"filterConfig" was my configuration.And it doesn't work.The fifo callback function still able to be interruptted by 0x200/0x400/0x600.
    And i find some information from "RM0349 SPC570Sx 32-bit MCU reference manual rev6, Dec 2015",please check attachment--"CAN mask".That means 3-13bits avaliable to standard frame.So,i used filter mask--0x1fff to check also.But without any improvement.0690X000009Yr86QAC.png
    Can you help me set-up the configuration of filter items?
    Thanks.
    Jer.
