RRama.8
Jun 27, 2019 8:39 PM UTC
how to compile code on a particular address.i have to write the application for that or i can use some tools for that.
    Erwan YVIN
    Erwan YVINBest answer
    Jun 28, 2019 8:46 AM UTC
    Hello ,
    You can create your own linker file (user.ld) and use __attribute__
    __attribute__ ((section (".codeinram"))) void gotoStandbyMode(void) {
    	WKUP.WISR.R = 0x00000008;		//Clear interrupt flag
    	if ((ME.GS.B.S_CURRENTMODE < SPC5_RUNMODE_RUN3)
    	 || (ME.GS.B.S_CURRENTMODE > SPC5_RUNMODE_RUN0)) {
    	 if (OSAL_FAILED == halSPCSetRunMode(SPC5_RUNMODE_STANDBY)) {
    	 SPC5_CLOCK_FAILURE_HOOK();
    __attribute__ ((section (".codeinram"))) void gotoRunMode(void)
    	 if (OSAL_FAILED == halSPCSetRunMode(SPC5_RUNMODE_DRUN)) {
    Best Regards
    Erwan
    Jun 27, 2019 11:49 PM UTC
    That's usually the function of the LINKER
    A Linker Script would define memory regions and names of sections
    The compiler would use attribute or #pragma to flag to the linker the section names the user has provided.
    Where the tools lack I've built linkers and object file manipulation/translation apps.
    Erwan YVIN
    Hello ,
    Best Regards
    Erwan
